Greetings,
I have had a Hayward SP-1580 1HP pump for several years and it was time to replace it. Not a big deal. I went to the pool store (ugh) and purchased another SP1580. As you can see in the attached photograph it leaked like crazy at the output to the Sand Filter. I tried multiple hose adaptors including the one from the old pump as well as a new one from Hayward and elsewhere. As with the original pump, tape was used on the adapters and wound clockwise. It never leaked.
Given the multiple adapters the only thing I could figure was that the outlet on the pump had not been milled flat, hence the leak. I bought a second SP-1580 pump from Hayward.
Fired it up tonight and it's leaking worse than the first pump I purchased to replace the original. At this point about all I can come up with is an inert sealant such as GE Silicone-II Tub and Bath or similar product to seal that area. But, is it in fact inert? I don't want to be putting any residual God-knows-what into the water. I've got Grandkids swimming in there.
Any thoughts, input, really appreciated.
Thanks All,
Lyman
Thanks All,
Lyman
