Before going down a road hours of research, I was hoping someone on here could answer a few questions with regards to selecting a replacement pump (as my current one is on its way out).
I currently have a 1.5hp single speed pump for an inground 18000 gallon pool with 2nd story solar heaters. The solar heaters are also pretty far from the pool so it is a long pip run over to them and therefore quite a bit of head.
The questions I have are
1) Is it worthwhile looking into a VS or 2 speed pump when I want to be running my solar panels the majority of the time? Or will I need to have the pump turned all the way up to get the required head?
2) Should I be looking at a much larger VS pump (maybe 3hp?) so that I could just run it at a lower speed (reduced power) and therefore reduce my operating costs?
3) Or should I just be replacing it with another higher efficiency single speed 1.5hp pump since I have the solar panels?
Thanks
Dennis
Thanks
Dennis
