SNAFU
I have Hayward ProLogic (PL-PS-8) automation and a Hayward Tristar (2hp) pump which replaced a Hayward Northstar (2hp).
Friday my Northstar stopped working. Capacitor had a burnt hole in it like there was an electrical arc that went through it. I bought another capacitor, but go no response from the pump when I tried to turn it on at the control panel. I assumed it was the motor, so I went to buy a replacement and ultimately decided just to spend the extra money and buy a new pump all together.
Installed and turned it on at the control panel, but again... nothing. Booster pump also not turning on at the control panel.
I wired the pump directly to the breaker and it runs fine. Booster pump also works wired directly to breaker.
I checked the main board and the board for the control panel, and don't see any obvious hot spots. I checked and replaced the fuses on the main board just for good measure.
Before I keep chasing this problem and drop another $500 on a new main board, what would you guys suggest I do?
I'm learning, sometimes it comes at great expense, but I'm learning.... Thanks in advance for any help.
