New member, New to working on my pool, and I have a new pump and motor....
I am three days into doing a SLAM. The pool was really bad as the motor died last summer, and we covered it over the winter to keep leaves out. We scooped and skimmed all the bulk waste from the pool (tons of stuff). We replaced the pump and motor with a brand new unit that matched the original equipment and started the SLAM three days ago. Because the pool was SO bad, we circulated water, bypassing the filter using a 2" hose for the first 48 hours. Yesterday at 4 pm, we vacuumed to waste, and then switched over to the filter. It has been running for 24 hours on the filter, and we are rinsing the filter, and strainer baskets regularly. So far, I am pleased with the chemistry experiment.
The pump/motor came as an assembly. It is a Whisperflo WF-28 with a 1.5hp motor. It bolted up, and fired right up when we turned it on. It is the same model and size as the original.
We have a Pentair Clean & Clear Cartridge Filter. In the past, a clean filter would run at 8-10psi. We would see a drop in water flow at 20 and would clean the filter. It appears that pressure right now is about 20-25. Other than stopping to clean the filters it has run constantly. During this SLAM, we have been running around 20 and cleaning at about 23-25. Today, even after rinsing the filter, the pressure is still elevated (about 15), so I imagine it is not really clean. I have a new filter but was continuing to use the old filter during the SLAM. We also changed all the O-Rings on the filter and added a new pressure gauge.
That brings me to my problem.
At about 4 pm today, I notice the pump motor was very hot to the touch and was making a squeaking/chirping sound. I have shut it down now to let it cool. I was reading different posts here about hot and loud pump motors and can only hope that I have not burned out a brand new motor with less than 72 hours on it.
Do you have any thoughts about what and why this has happened? Is pressure too High? Do you think my pump is fried? Do you think this is a product issue? Do you think I can cool it down, reduce pressure, and continue on?
Sorry, Lots of questions.
Thanks.
Harry
Thanks.
Harry
