Hi,
My pump kicked the dust and need recommendations for a new one. I'm trying to get it right so as to be efficient as possible. It is a simple set-up:
~5000 gallons
12x18x4 oval
S180T Hayward Sand Filter.
Now... about two years ago, I had a plumber friend utilize my heating oil boiler to heat the pool -- and it has worked out pretty well. The connections to the boiler run out of the 'return' from the filter. So, it's a basic set-up... with the exception that instead of the water being returned right back to the pool it is diverted to the boiler (unless I set the valves to bypass this). As shown in the pictures, the pipes run along the base of the house, up about 5' to where it enters/leaves the basement <about another foot past the edge of the picture> to the two copper pipes that run vertically in the basement picture (to the right of and behind the hot water heater). The pipes and connections in the middle of the basement wall are all pretty much for the pool. So, there are multiple turns, feet of pipe, etc.
So, armed with all this information, it would be greatly appreciated what pump would be recommended. Note that I was in the process of changing sand, which is why the multiport was not connected. If it's felt that an upgrade to the "barrel" of the filter is needed then now would be the time to do so before the new sand is added.
Thanks in advance!
~5000 gallons
12x18x4 oval
Thanks in advance!
