New propane heater install
pagreenpool
57
Allentown, PA
I'm getting info on installing a heater. We have a 22k in ground pool, live in eastern PA. Our home is oil heated, but I have a 100 gallon propane tank for the oven.
In my research, the consensus seems to go with a larger heater (more BTU) to heat the pool faster. So I'm looking to do that, however I feel I might be limited by the size of my propane tank or possibly even the hookup - there is already a line ran from the propane tank to the pool, it's 3/4".
So if I get a 400k BTU heater, is it going to rip through that 100 gallon tank? My options are get a 2nd 100 gallon tank, or we are thinking of possibly buying a larger tank (500 gallon or 1000 gallon), and eventually switching the house heating to propane.
Thoughts?
Thanks for all the feedback. I have a 3/4 inch line already ran to my equipment pad for the propane hookup. Is that size line going to limit the size heater or can I still get a 400k BTU? What is the point of getting anything less than 400k?
Is there going to be a second stage regulator there by the heater? Usually they run the propane under high pressure and use a small line so I would guess that you have 3/4" pipe showing above ground but the smaller copper line underground which is normal. I see no issues with it.
