I have moved and now have an in-ground triangle shaped pool about 10,000 gallons. The pool turned green and when I spoke to the pool maintainance man he didn't know anything about the pool. all he did was hold up a chlorine test strip and say "the pool has no chlorine, I'm going to dump a lot in." Two days later I get my test kit from storage and my results are as follows:
FC 30
CC 3
TC 33
CA 425
TA 40
CYA 60
No chlorine has been added to the pool since his initial dumping in of chlorine by this pool guy. I called the rental management and they asked me if I was interested in maintaining the pool, I said okay. I'm going to go out later and figure out the type of pump and size. Only change i've made so far is to change the pump time from 3pm-8pm to 12pm-8pm. The guy must have dumped a ton of chlorine in this thing for the levels to still be 30 in the south Texas summer sun 2 days later.
The pool is now blue but cloudy. I am going to let the FC come down to suggested levels for shock then do an over night test to make sure all organic material is dead. Would you guys suggest any thing else based off my results?
FC 30
CC 3
TC 33
CA 425
TA 40
CYA 60
