Hello! I’m replacing my single-speed 3/4 hp pump with potentially a much higher capacity variable-speed pump. Also, I have a dead booster pump for a Polaris that’s been out of commission for a few years, but never bothered to replace because I don’t mind vacuuming myself all that much. I have two questions:
1. I’ve attached a photo of my current plumbing. With my existing configuration, can I remove my inoperable booster pump and run the Polaris robot with the variable-speed pump alone (just run it at a higher speed than normal)? When my current single-speed pump runs I can feel a bit of water coming out of the robot outlet port on the return side which is why I’m asking if this is possible.
2. If I can’t have One Pump To Rule Them All, can I swap out my dead booster pump with my soon-to-be retired single speed pump? The single-speed pump is still working, I’m just replacing it for energy savings / noise reasons. Thus I’d have a single-speed pump alongside a variable-speed for the sole purpose of running my robot when necessary.
Thank you for your help!
