Hi all -
I'm installing new PVC pipes at the pad and have the opportunity to do it right from the get-go. Pool has 2 skimmers that merge to 1 line, 2 return jets that merge to 1 line, 1 return jet from the old booster pump for the Polaris cleaner, and a main drain: 4 pipes that lead to the pad. I also have an electric heat pump. Pool originally had 1.5" black poly pipes that I have transition to 1.5" PVC. I live in Massachusetts so the equipment is disconnected each winter.
Can you please tell me:
- ideal places to place unions for the return jets and suction side
- type of valves to use and where
- ideas for a backwash pipe to lead away from the pad area
- port for blowing out the pipes for the winter
Pictures are worth a thousand words!
Thank you.
Thank you.
