- Jun 17, 2022
- 5
- Plaster
- Liquid Chlorine
- Autopilot Digital Nano+ PPC2
Greetings from Myrtle Beach, SC! We are new pool owners of a 10,000 gallon pool that has a Triton II TR-60 Filter and a Pentair Multi-port valve. We have desperately tried to find a pool guy to teach us some things about how all of the pieces of equipment work together, the proper way to vacuum, etc. with no success-- they're all too busy and will not return phone calls! So we had no other choice but to learn things on our own.
My question today is this: how to we vacuum our pool- what steps to we take to shut the pool off? I know how to fill up the hose that goes to the vacuum with water, stick the hose in the skimmer, etc. But my biggest question is: is it best when you have a lot of debris (we have pine tress all around us) to vacuum to the filter or vacuum to waste? Of course was you think, but if we vacuum to waste it drains the pool too low?
We were vacuuming today; the pool water level got low, we turned off the filtering system, put more water in the pool (but not enough, in my opinion), and turned the vacuum back on (vacuum to the filter.) Since we're turning the skimmer on, we must also turn on the main drain, right? (Note we're still filling pool with water at this time as well). We look outside and the pool level has dropped even lower (which I told my husband it would happen) So my pointed questions are:
1. when vacuuming a pool- your water levels should be high or at least just right, correct?
2. Can you turn on the skimmer but turn off the main drain (both suction lines) when you're vacuuming through the skimmer?
3. What is the best way to vacuum?
I thank you in advance for your time and consideration on this!
Cyndi Lou
Cyndi Lou
