Hello all,
We purchased a home with a below ground, 20k gal, textured/plaster pool + spa. For the last month or so I've been using a 5-way pool test kit and Leslie's to get all our measurements, but after getting a couple readings from Leslie's that seemed way off we ended up getting a Taylor K-2006 test kit. Our first test results show:
CYA 60
CH 625
TA 100 (80 if adjusting with 1/3 of CYA)
PH 7.8 (honestly, my color matching skills are pretty poor...3 or 4 drops of acid demand got me close to 7.2/7.3)
FC 7.2
CC 0
I was a bit surprised by CC levels. We've been seeing some discoloration on the sides of the pool and small amounts of what we are thinking is algae (i.e. quarter-sized) in the pool after having a house warming party about two weeks back. We shocked the pool with cal-hypo (Power Powder Plus - 2 1lb bags), and saw the discoloration clear up in a day, but never get crystal clear clean, so I figured our FC was still getting eaten up and was expecting to see *something* in the CC, or maybe very low FC.
Anyway - I'm looking at the ideal levels as suggested by TFP, and I'm seeing 350-550 CH and 40-50 CYA. I tested our tap and we're at 200 CH. I think draining a bit less than 1/3 of the pool and filling with that should give us the CYA of around 40 and CH around 500, which puts us into the "ideal" range for those, and then I can SLAM in an attempt to kill any algae that might be in there. After that I'd re-measure the TA and try to get to a decent CSI?
Thoughts? I'm mostly looking for some sort of verification before I do something stupid... =)
Oh, also, when people/tools mention the TA measurement, (e.g. "ideal" level in TFB being 60-80), is this the "adjusted" measurement where we remove the 1/3rd CYA? Or would the ideal be an "unadjusted" measurement of 60-80 in the presence of 40-50 CYA?
Thank you!
CYA 60
CH 625
FC 7.2
CC 0
Thank you!
