Hello, I am a new pool owner with air in the pump.
First of all, I have a kidney shaped pool, approximately 20,000 gallons. It's in-ground, with a vinyl liner and it's right under a massive tree that drops tiny leaves constantly. I have a pentair whisperflo pump with a pentair clean and clear plus 420 sq ft cartridge filter system (fairly new). Additionally, I live in Wisconsin, where the season only lasts 3-4 months.
Anyways, the pool has a functioning skimmer, but the main drain was covered when the new vinyl was put in. My guess is that it was non-operational due to a leak in the pipe and it was too expensive to repair. Either way, I am running on the skimmer only. I bought a vacuum for manual operation and am working on purchasing a robot to do the rest.
The problem that I have is that I can't seem to get the pump to run air free. I have changed the O-rings at the basket and valves. I have taken apart the pump and cleaned it out as much as possible. I have changed the cartridges in the filter. The water level of the pool is good. I am thinking there is a leak somewhere so I tried using a hose to see if I can drown any leaks along the way, but it doesn't seem to make a difference. I am thinking about buying some insents to see if I can track the leak with the smoke, but otherwise, I am running out of ideas.
Any thoughts?
Any thoughts?
