Hello
New pool owner, just set it up 2 weeks ago, ran it a week and a half on the filter setup that came with it but now have an Intex 3000 gph sand filter setup and an over the top Intex skimmer that is in the mail at the moment.
Went to Lowes and bought a box of shock, pool tablets for the floaty that I read is frowned upon here so that was probably a mistake and I also bought something to raise ph because at first
using the strips that came with the pool it showed the ph to be low, now I am not to sure that was true. Used enough shock the first few days to make the test strips happy and the water is very clear so far.
After spending a few hours on here I ordered and received a TFT-100 test kit and tested the water and here are the results from the first time using the kit last night.
FC--3.5
CC--.5
CH--450
TA--320
CYA--50
Didn't record the PH for some reason but I think it is high around 7.8 or 7.9
Not sure how long to run the pump everyday since it will filter all the water in the pool in about 2 hours.
Where do I go from here ?
Thanks
Donnie
FC--3.5
CC--.5
CH--450
TA--320
CYA--50
Thanks
Donnie
