- Nov 26, 2013
- 168
EPA standards for drinking water pH is 6.5 to 8.5. These are secondary standards, which are not requirements and just guidelines.
Nope. That's it. You just need to know if you'll be needing acid or borax or baking soda to fix pH and TA up front so you won;t be scrambling around trying to find it when the kids are whining to get in.Pool was delivered yesterday!Now just need to wait for the installers to schedule.. I'm gonna hit up Ollies and get some bleach and acid this weekend..
I don't need to do any other tests then pH and TA before I fill the pool then?
Pool is installed and filling up with two garden hoses..
So once it gets filled up and circulating, I'm to add 4-5 lbs of stabilizer? Do I just measure out around 64oz's and stuff it into a sock and put it in the skimmer?
When do I start adding bleach and do some tests?? I got my test kit but unsure of what all to test..
Thanks!
I have the TF-100, so it's a little different, but here's what I think.
OK, 4 lbs of stabilizer should get you to CYA of 30. That's good to shoot for. Put in a sock or 2, but not in the skimmer. Hang it in front of the return and squeeze it once in a while to help it dissolve. Like this.
Run a set of tests for everything but Chlorine and CYA as they are zero, then post them here.
pH - (right side of the block test)
TA-
CH-
Use Pool Math to see how much chlorine you need to add for CYA of 30. Use FC=0, target FC = 6, CYA of 30 and the correct percentage for chlorine. (Do you have some?)
Wait an hour for it to mix, then run a set of tests for Chlorine. (Run both the block test (OTO) and the FAS-DPD to see how they both work) Post the results here.
Once we see your ph, TA CH, FC, CC we can make recommendations on those.
Don't worry, the tests can be intimidating at first, but once you get used to them it will be easy... Promise.
Thanks for the reply.. So I should run those tests right after I put the socks in?
And yea.. This is *very* intimidating..
