New Pool Owner, ran TFT Pro test and need some direction
ravinath
17
Warren, NJ
Hayward Aqua Rite (T-9)
Hi all,
I'm a new pool owner of a SWG pool. Ran the TFT drop test and used pool math. Looking to see which steps should i do first or do i do all 3. See results below. thanks for your help.
Test your FC at the same time daily and make adjustments to your SWG until you find a setting that matches your daily FC loss. Then you may choose to go longer between tests. I try to keep my FC near the higher end of the range. If you fall below the minimum, algae may take hold. You may choose to add liquid chlorine to quickly increase to the high end.
You can start to slowly increase CYA to 60. Add granular 100% CYA a little at a time and then test a couple days later. You don’t want to overshoot.
I would leave TA alone. As your pH rises you will add Muriatic Acid which will also lower TA. If TA gets down to 50 you can increase with baking soda.
