Hi all. I recently retired and purchased a home with an existing pool. I have never had a pool before but am getting up to speed on water testing and maintenance.
Here is where I'm at:
The pool is 4 years old and all the equipment is original
It is a salt water pool but the SWG has died (its been thoroughly cleaned but it hasn't helped)
I recently cleaned the filters. They were very dirty.
There is significant scaling at the waterline of the pool and particularly at the spa spillway (1/8" thick in spillway area)
CYA and calcium are high
The pool has never been drained
Here are the water chemistry numbers (Using Taylor 2006C Test Kit):
FC and TC - 8 ppm (I've been gradually increasing to recommended value of TFP}
pH - 7.5
TA - 65
CYA - 90
Calcium - 1225
Salt - 4500
Temp -85
CSI per Pool Math is .04
Short term plan for this swimming season
It seems like the best course of action would be to drain the pool or have RO done (due to high CYA and calcium) but I don't want to do this in the middle of pool season. It's routinely 105 degrees here in Tucson so I am using the pool almost every day. I have ordered a new SWG but they are back ordered 4 to 6 weeks and no promises even then. So, short term this season I plan to maintain it as a conventional non-salt pool. To deal with the scaling issue I am monitoring pH and TA closely and keeping them deliberately on the low end to keep the water balanced with the very high calcium hardness. The scaling has gotten better now that the water balance is improved. It was much higher when I first moved in and a pool service was maintaining the pool. I am using liquid chlorine as a sanitizer since other options will either increase CYA or calcium hardness which I do not want.
Long term plan after the end of the pool season
Have scaling removed
Either drain the pool or have RO done at the end of the season after scale removal
Install new filters and new SWG
Add required salt
Refill and rebalance the pool water
Would appreciate critique/advice if I am on the right path here.
Thanks in advance.
pH - 7.5
TA - 65
CYA - 90
Calcium - 1225
Salt - 4500
Temp -85
Add required salt
Thanks in advance.
