Re: New Pool owner - bought a pool and house that are 1 yr o
hmm... I posted a reply to this a couple of days back. But, it wasn't posted.
Anyways, BIG Thank you to everyone. Now, the cya is 60 after the refill... Here are the test results after the refill.
FC - 1
CC - 0
PH - 7.7
TA - 125
CH - 400
CYA - 60.
Added chlorine to bump up the FC to 7.
No improvement with TA and CH. Should I be concerned about high TA and CH?
If I should, I'll add Muriatic acid to lower PH then aerate for TA. May be do a partial drain and refill with softener water to lower CH.
I have waterfalls. Can I just run that to raise PH after adding the Muriatic acid? or do I have to add anything to aerate?
Thanks again!
FC - 1
CC - 0
PH - 7.7
TA - 125
CH - 400
CYA - 60.
Thanks again!
