Hello, I ordered a 33‘ x 18‘ above ground pool with 15,500 gallons. It will have one skimmer and return line both 1.5 inch. . I’ve calculated my turnover at a minimum of 32 GPM based on one turnover in 8 hours. I have decided that I will go with a VS pump and Cartridge filter. My ultimate goal is to have the least maintenance possible and would like to oversize the filter. I was looking at Hayward Max-Flo VS Variable Speed Pumps along with other Hayward and Pentair VS pumps. There are so many VS pumps to choose from that it’s left me more confused after days of research. I’m not sure which pump would be best. Along with a VS pump I was interested in a large or extra large cartridge filter. Something that would reduce the cleaning period to twice or if possible once a season. I do understand that cleaning frequency has many variables such as debris and dust so I was thinking a extra large filter would not hurt. I see filters such as the Hayward Swim Clear Large Capacity Cartridge Filter, 325 sq ft and 425 sq ft and similar sizes from other manufacturers. I’ve even seen one from Doheny’s with 525 sq ft of area. Would such a large filter be overkill or detrimental? I can’t seem to find any concrete info on the minimum Sq ft of cartridge area needed for my pool. If I knew the minimum then the numbers would be easier to interpret. My research leads me to believe that when it comes to cartridge filters, the bigger the better and go with the largest that your wallet will allow. Is this true? I will also be installing a Salt Water System but have yet to start my research on that.
Any help that you can provide on my VS pump and filter questions would be greatly appreciated. Thanks in advance for your time.
