sddiver
0
Re: New Pool IG - Inland Empire, CA - 10/22 Pool overfilled and plaster cracks! Help!
the small cracks are normal I think (surface checking). The valve was probably set to pull from the spa drains until you switched it. Normally that valve would bet set to pull from the pool drains/skimmer unless you were running in spa mode in which case the return would also bet set to return to the spa at the same time. This should be fine and you should be able to open the pump top when without a flood when the suction valve is set to pool drains (assuming your pool water level isn't higher than your equipment)
