So we closed on a house 3 weeks ago and I imagine I am doing a lot of somethings wrong here.
Pool is 20x40 with a spa. Previous owner maintained the pool himself and it was always beautiful.
I have been adding 4 chlorine tablets to the skimmers each week (2 in shallow, 2 in deep) as per prior owner. For the first 2 weeks the pool was doing well, chlorine tested normal (3 ppm or so). Last week we cut down 2 pine trees that were dropping needles in the pool. I noticed at that point the chlorine levels were testing at low to non-existent. I added 4 more chlorine tabs in the floaters. At the end of last week the weather got really hot. On Sunday I added more chlorine tabs when the skimmer ones were shrunk down and the levels were still close to zero. Yesterday I tested again and still close to zero. The pool was then somewhat green. Today the pool is bright green. The filter is running about 20 hours a day with the pressure showing about 20 psi.
I am having a pool cleaning company come in the next few days to clean it out and teach me how to maintain as I am clearly missing something.
I had a Polaris 9550 for the first 2 weeks and just switched ot the maytronics M400 this week. I have them running every day.
My question is: Is this just algae and I need to put in algaecide? Is it likely my filter is clogged, hence the low chlorine levels? I see water running through the pumps and filtration system, so I imagine it is not.
Thanks!
Thanks!
