Although I have been a lurker in these forums for a number of years…I have never followed the TFP method for balancing for my pool. My pool tile line was suffering and I was needing more chlorine tablets…last week my pool store numbers included CYA 200+ and Calcium 800+. I have a new religion, so I:
But now I have my “REAL” numbers and am trying to figure out what next:
Ph 8
FC 3.5
CC .5
CH 200
TA 140
CYA 35
I definitely have to work on the PH (add acid). Should I lower the TA a bit using acid+aeration? I am leery about adding calcium because we have such hard water in AZ and I suspect that it will be up by the end of the summer significantly just due to evaporation/auto-refill. I plan on using liquid chlorine from here on out except occasional tablet use when travelling.
Any advice? My pool stats are in my signature…one question in particular, are pebbletech pools considered the same as plaster pools for calculations?
- read through 80% of the relevant pool school sections (no, I don’t remember it all)
- ordered my TF-100 Test Kit…I received it today and tested for first time
- drained and refilled my pool
- added about 56 dry oz of CYA before I received the test kit (calculator recommended 72) and have been adding liquid chlorine to keep the chlorine readings above 3
Ph 8
FC 3.5
CC .5
CH 200
TA 140
CYA 35
