Needing some help on the equipment plumbing layout and design.
I have 2 2in skimmers that are separated, 2 2in bottom drains that are tied together, 4 1.5in returns tied together with 2in, 4 1.5in bubblers tied together with 2in, 3 3/4in deck jets fed with 1.5in trunk and a 1in for the slide. I have a 2in Hayward S244T2 300lb sand filter, a Pentair 120/240 1.5 HP Superflow and a 240v Sta-Rite Intellipro VSF 3HP. I don’t have a heater currently but will have once once I get my propane tank so I want to install valves to tie that in later. My plan originally was to use the 3hp pump for filtering and the 1.5hp for features but now I’m not sure that’s the best way to do it or how to go about laying out the plumbing for that. I’ve since back tracked and decided that may I just need the VS pump since its not likely I would have the bublers, deck jet and slide all going at the same time. I’ve attached a picture of a rough sketch that I’ve drawn up. Also I have the Intellicenter load center i5P pool only with 40k cell, 3 intellivalves, 3 micribrites, this is all new to me since I’m coming from an above ground pool. It already looks like I have an issue with my intellivalves since there are only 2 connections for them in my panel, so I think I may need an expansion board. I appreciate any help you all can give me this forum has always been a big help with my previous pool.
