- May 28, 2024
- 9
- Plaster
- Jandy Truclear / Ei
Hello - just had a new pool completed about 3 months ago. I had a pool several years ago, so not new to maintaining a pool but have some questions on this one.
1) I can’t seem to get the ph down below 8, I have added a ton of muriatic acid over the last couple months, probably 8gal but it just never dips below 8.
2) I have been running the SWG at around 90% but the chlorine doesn’t get above 1-1.2, SWG should be able to keep up with the size of the pool - it’s a Jandy TruClear and the pool is roughly 26K gal.
3) The builder installed the Jandy Watercolor nitchless led lights, but I really wanted the Infinite Watercolors lights, is it the same mount? Can I just swap them out and add the Jandy transformer?
Thanks in advance.
Ben
Thanks in advance.
Ben
