- Sep 11, 2024
- 4
- Vinyl
- Hayward Aqua Rite (T-15)
Hey there. New to the forum and first time SWG pool owner here. I've read through a lot of the info on the website and some of the forum threads but feel like I might need a little one-one-one help. Think I have a good idea of what to do but looking for some reaffirmation.
We got our pool done and filled in late July. Filter, pump, SWG all up and running. Salt level is at 3,000 ppm. My issue is that I've been running the pump/filter/SWG about 12 hours a day and I can't get the chlorine level to even register on my tests. Only once in the last 40+ days has my test shown a chlorine level and it was barely registering then, probably < 1 ppm.
My PH has been staying too high, over 8 for sure. I've put probably four or five 5 lb bags of the Clorox PH reducer in it over the last month or so. PH will come down into the 7's for a day or so and then bounce back up the next day. After doing research on this, I figure I need to get the alkalinity down first right? And yes, my alkalinity is staying too high too, but again, using the PH reducer granules don't seem to be doing the trick. Should lower the alkalinity/PH with muriatic acid instead of the Clorox PH reducer? Is it true that the more I run the SWG, the more the PH will increase? Is the high PH and alkalinity the cause of my chlorine not registering when I test the water?
