New Pool Build - Philadelphia Area
casind05
4
North Wales PA
Hi All - learned a lot of great info lurking in these forums and wanted to post about our new pool build happening end of this summer and see if anyone had any input on design/features that should be switched or added.
We decided to do a fall dig/spring 2023 finish just so we didn't have to lose our yard for an entire summer.
A couple things we are debating - location of the spa more towards the back of the pool area, widening the pool on the side near the sun shelf for more hang out area in the shallow end. Possibly adding tile inlays on the steps. Final debate is to add a dual heating system - heat pump on top of the propane due to the costs of heating the pool with propane year round. Yard isn't full sun, i am unsure if this is necessary.
Is this pool going to feel small or large? We have never had a pool before and are wondering if we should squeeze in as much pool as the setbacks allow or if the size is OK.
Freeform Pool
23k Gallons
25x40
4 LED color change lights - 2 pool,1 sun shelf, 1 spa
Spa - 50 sq ft - 8 jets
Ansylbrite Quartz Finish (leaning towards Cobalt color)
Pump: Jandy 2.7 HP Variable Speed
Sanitation: SWG (waiting on the brand from the PB, we originally started with an In-Line Chlorinator but upgrading)
Heater: Propane, Raypak 399k
Automation: Jandy PDA-PS8/iAqualink
Decking - 1000 sq ft, brushed concrete. (Rendering shows stamped, we decided to switch due to ongoing maintenance and personal preference)
Thanks for looking!
Spa location: towards the back of the pool will give you a clean look at the pool water with no obstruction for viewing swimmers due to the spa being a RBB. Also you get full sound of the spillway from the spa.
Tile line inlays (see pictures)
25 X 40 is a good size pool but unaware of the size of the yard it’s going in.
Inlays look great! Def asking the PB to quote on adding these.
go sun shelf right to 4 ft
Yes with steps to help get out. Most people tend to just jump in so the steps are really more for getting LOL
Is 6ft deep enough?
well lets go there! Do you want to be able to dive into the pool? or just cannon ball in? If you want to be able to dive off the edge of the pool you will need it to be at least 7' deep. Now if you put in a diving board then it is 8' with the slope being done by the rules set up for that. We can get into that if you decide to go that route.
-6' or more to be able to cannon ball in
-7' or more to be able to dive in
Kim:kim:
