- Jul 2, 2018
- 650
- Plaster
- Pentair Intellichlor IC-40
We've made progress. The PB we like sent us a proposal back. Feedback is appreciated.
WE WILL PROVIDE THE FOLLOWING:
POOL SPECIFICATIONS:
Dimensions: 32 ft. x 17.5 ft. x 19.5
Inside Perimeter 103 sq. ft.
Surface Area: 540 sq. ft.
Approximate Volume: 21,000 gallons
Depth: 4.0 ft to 6.0 ft
Steps: One set per plan
Benches / swim outs: 20 lineal ft.
Lights: (3) LED Globrite color pool lights
Tile: Per owner’s selection
($5.50 per sq ft allowance included)
Coping: Pre cast salt damage resistant coping or poured in place concrete with approved finish and edge design or approved equal per owners’ selection
Water features: Raised beams / Retaining walls with 4 scuppers / sheers (Water feature style to be determines)
Other: Umbrella sleeves, volley ball sleeves
SPA SPECIFICATIONS:
Dimensions: 8 ft. x 6 ft. inside dimensions, 18 inches height
Controls: Pentair Easy Touch with wireless controls or Screen logic controls with smart phone application optional
Jets: Six Waterway therapeutic jets
Light: (1) LED Globrite color light
Heater: Pentair 400,000 BTU gas
Drain: Dual anti vortex drains
Coping: Lueder limestone or approved equal.
Blower: 1 HP Air Silencer Blower
EQUIPMENT SUMMARY
Pumps (1) Pentair Inteliflo variable speed for pool/spa
& water features
(1) 1.0 HP Whisper flow water feature pump
Filter: (1) Pentair 60 DE w/ multiport valve
Water Treatment: Pentair IC60 and In Line Automatic Chlorinator as back up.
Pool Cleanerentair racer with booster pump or equal
Heater: 400,000 BTU Pentair Master Temp
Skimmers: (2) in pool with customer pour lids
Auto fill: Pool miser with anti siphon devise and over flow drain pipe. Not warrantied against freezing
Lights: (3) LED Globrite color lights in pool and (1) light in spa
Drains (2) anti vortex in pool and two in spa
Controls: Pentair Easy Touch 8 with wireless remote or Screen Logic remote for smart phone.
Equipment Pad: All equipment is set on a concrete pad.
Maintenance Equipment: Wall brush, net and telescoping pole
Start-Up Chemicals: Included
DEMOLITION
Removal and disposal of approximately 300 sq. ft. existing concrete.
EXCAVATION
Backhoe / Bobcat: All dirt or rock excavation, bagging and haul- off included in the pool base price. Rock excavation of access is included
Forming: Excavation to include all forming of pool and included elements, i.e. beams walls water features and decks.
POOL BUILDER accepts no liability and assumes no responsibility for landscaping, sprinklers or any other fixture replacement due to completion and alteration of existing property due to contracted project. “Owner” assumes all liability to complete landscape after the pool and associated projects or items are complete unless stated specifically in the contract.
STEEL
GUNITE
PLUMBING
ELECTRIC
DECKS
FENCING
RETAINING WALL
PLASTER
· Level 1-2 pebble finish per owner’s selection included.
PATIO COVER
20 ft x 19 ft Patio cover with matching shingles to house. Ceiling board to me tongue and groove or approved equal painted or stained per owner’s selection. All trim and columns panted to match house.
Hard spots provide and wired for ceiling fans and lights as directed by owner. Light fixtures to be supplied by owner. Installation of lights or appliances included.
WARRANTIES
· Lifetime Structural Warranty on the Pool Shell To Hold Water
· Pool and equipment 36 months bumper to bumper.
· Tile, coping, plaster, pool sweep 3 years.
· All Pentair Equipment 3 years parts and labor
· 3 year workmanship warranty on all items.
ADDITIONS:
· All State and Local taxes included
· Building Permits and HOA Architectural Review approvals included.
· Licensed structural engineer consultation and design as required.
· Clean up construction site of all pool construction related items.
· Pool School / Customer orientation
· One month Pool cleaning and chemical service included
- All work to be done in accordance with the National Spa and Pool Institutes Specifications as well as all applicable local codes.
- General Liability Insurance during construction
- Layout in accordance with approved plan.
- All permits and calls for necessary inspections.
SPA SPECIFICATIONS:
EQUIPMENT SUMMARY
& water features
DEMOLITION
EXCAVATION
STEEL
- 1/2” Rebar tied on 10” Centers with a four bar beam and additional bars at all high stress areas if required. Structural engineer to be consulted as needed for any additional requirements.
GUNITE
- Dry Gunite per industry standard, Water and Quality Controlled at Job Site
- Minimum floor and Wall Thickness of 8”-10” (12” when out of ground)
PLUMBING
- All plumbing with schedule 40 PVC 2” plumbing to skimmers, spa, main drains and water features. Larger plumbing may be required for extended plumbing runs.
- Separate main drain and skimmer lines with independent valves.
- Independently plumbed suction lines for water features
- Two Pool Main Drains (anti-vortex type)
- Skimmers (qty. 2) with equalizer intakes
- Gas line and hook up of heater included.
- Area Drains in decks as required. Down spouts drains to be included
ELECTRIC
- Bonding by Electric Code (#8 copper wire)
- Hook Up of Under Water Lights, Timers and Pool Pump
- Includes all circuit Breakers, GFCI, Etc. 1 YR. warranty on GFCI breakers
- Freeze control
DECKS
- 247 sq. ft. travertine pavers set on compacted road base and mortar base per owner’s selection or equal. Reinforced containment walls (+/- 3 ft. ft. ht.) and footings for columns.
- Existing concrete to remain to receive matching travertine pavers with mortar base.
- Install sleeves under decks for irrigation and electrical as required.
- Area drains as required.
- Hand and guard railings to code included.
FENCING
- Approximately 15 ft. wood fence and equipment screen and gate to code.
RETAINING WALL
- Retaining wall shall be constructed with matching stone beyond pool raised beam toward gate as required.
PLASTER
PATIO COVER
WARRANTIES
ADDITIONS:
