Pain based..............and it worked. VERY interesting! I wonder if it released the "pressure" the discs were causing? humm so neat that it worked!
Kim
Kim
You get your decking done yet?
Your firepit is awesome!!! OMG - ya'll are going to love it! You might end up really liking the black glass. I know it will be easier to clean, but black glass might reflect the colors of the flames better. I don't know anything about firepits. I'm just making a guess.
The heat for your spa is coming just in time for your neck! And when you get too warm, you just slip into the main pool!!!!
That's what I plan to do when the pool starts getting a little too cool. Heat the spa to warm up in, then back to the pool to cool off!! I'll have to see how that affects my bills! That may be a luxury I can't afford.
Be sure to remember us with pictures of the firepit blazing!!!
Suz.
Now to order FireGlass. Kinda bummed - since I have propane, I need to go with black glass - the glass company said that the propane causes soot - and unless I want to be cleaning it all the time, I need to stick with black. BUT I did find a place that has a GREAT sale going on. http://www.fireonglass.com/
I went with a mix of black, dark blue and clear glass, I'm still running propane. There are a few pcs that get some soot but really minimal, since most of the colors are dark it doesn't show much. I got the "jelly bean" glass, smooth rounded shapes, opposed to the more jagged pcs. If you need to you can use a shop vac to remove the glass, throw it in a bucket with soap and water, and clean it. I have also just taken a wet towel and rubbed the glass to clean and mix it around. Heres another glass place: Fire Glass | WoodlandDirect.com: Fire Pit Fire Glass, American Fire Glass, Krystal Fire Glass
Best wishes to Little Bear for a complete recovery!
That's hilarious! You had me going... I couldn't look at the picture until I read further. I can't 'bear' to see wounded critters. If you find out who the culprit was, be sure to let us know. I'd love to hear the story behind this!! Was it simply wanting a friend to see the pool, curiosity whether Little Bear could swim, a jealous fit of rage???
Suz.
That glass site has some great info.
When I was filling my pit I just winged it.
The PB was going to put cinder blocks under a sheet of cement board an inch below the ring then fill with lava rock.
I told him he was retarded, and should give himself an upper cut.
I got him to fill the lower part with drainage rock to 2" below ring then top with lava rock.
Seem this website agrees.
I was thinking (when I upgrade to glass) of putting a sheet of stainless mesh between glass and underlying lava rock so they don't mix.
The web site seems to indicate you just put the glass right over the lava rock.
I was thinking this would be hard to get out and clean. I have NG, but cleaning will eventually be necessary.
Still can't decide between the pebble style or crystal style.
I like the look of the pebble when it is not lit.
But I don't know if the crystal version would be more brilliant when lit.
Food for thought.
