- Jul 21, 2013
- 65,253
- Plaster
- Pentair Intellichlor IC-60
.. what are you using to read your salt level?
Use the https://tftestkits.net/K-1766-Taylor-Salt-Test-p31.html
I have the TF-Pro test kit with the salt add-on that ajw22 linked above. I also bought the standards so I could compare my testing against known standard solutions.what are you using to read your salt level?
That's about as close as you'll ever be. As the water evaporates or gets a boost from rain, you will see +/- 2 inches which is about 1200 gallons for you from high to low. So any given day will be up or down 600 gallons from 'perfect' Even more if you don't catch it in time.it seems to agree, within about 1000 gallons
It was at 60%, the initial setting by the PB. I turned it off for a couple of days, now it’s at 30%, with the pump running 12H/day (5h @ 1875RPM, 7H @ 1250RPM). I was last able to check FC on Saturday, it was 6.What a your SWG set to?
This little guy was a life saver when I opened my new pool last year; takes a salt reading with no effort while I’m testing chlorine and TA:I have the TF-Pro test kit with the salt add-on that ajw22 linked above. I also bought the standards so I could compare my testing against known standard solutions.
Got it. I didn't realize I needed to get it that high. Thanks!I would get your FC up to 5-7 using LC
As long as the final criteria (clear water) is good, then yes .... you passed!Did the OCLT last night/this morning, found a drop of 0.5 (FC of 5 at 11:39PM, FC4.5 7 hours later). CC is 0. That’s a pass as far as I know?
Looks crystal clear to me! Here’s the main drain cover down 6’:
