- Jun 20, 2021
- 11
- Fiberglass
- Hayward Turbo Cell (T-CELL-5)
I think it may be stuck in spa mode as the blower comes on but the pump doesn’t work in the pool. When I turn pump off in spa mode and move it to pool mode, it says it’s priming, but no noise, and never turns on pump filtration or allows waterfall to turn on. PB also recommended checking for phosphates as they could have eliminated the chlorine to begin with.Yes & yes. Be sure to elevated your FC to the appropriate level as noted on the FC/CYA Levels. If your salt cell is not on or operating, then use the Liquid Chlorine tab on that chart and increase your FC to the target range to avoid algae. If you have more questions about your equipment, feel free to post back.
