Pebble is only 2 months old so I realize pH can be high for up to a year. So if pool math is saying add 39oz of MA every 2 days, that's what I should do? I assume that doesn't harm the pebble in any way? also, when adding MA....I have a return jet on one wall of pool and it is a few feet from 1 of my 2 skimmers. Do I need to shut that skimmer off when I add the acid?
Here are my my most recent readings
FC 2.5
CC 0
pH 8.2
TA 80
CH 250
CYA 50
so more acid, and then I have to get my FC up to about 6?
can I venture to add borates to the pool? I read this on the forum it says : The only situations where we specifically recommend using borates are for pools with a negative edge or other very large water feature creating huge amounts of aeration and for spas using the dichlor and then bleach method.
I have a negative edge and my spa overflows into pool on 2 edges so I assume I am case where I should definitely use borates?
FC 2.5
CC 0
pH 8.2
TA 80
CH 250
CYA 50
