- Mar 15, 2017
- 106
- Plaster
- Jandy Aquapure 1400
Hi, so I am finally getting round to redoing my pad, this is what I have now:
I plan to rip it all out, make a nice concrete pad all the way to the edge of the house, leaving a rectangle of earth for the pipes to come up out of the ground. I have a new multiport valve to replace the T valve, and I am adding a Stenner pump and 30 gallon tank to inject acid to combat the SWCG as no matter what I do I can't get the acid level to settle down.
First question, in the below pic, the 2 black pipes on the left next to the automation, one is capped (white top) and one is capped but has a large slit cut into it, I presume that is air intake for the spa, but what would the other sealed one be? I have not dug up the pipes yet so don't know where they run to.
Second question, I want to simplify the layout, I don't need the manual valve that balances the pool/spa return (spa has a waterfall spillover) as I use the automation spillover now. Have I missed anything in the below layout?
I also plan to move the automation unit and mount it on the wall on side of the side of the house.
Any tips, suggestions would be appreciated, I thought about a heater bypass valve, but don't think its necessary?
Thanks
Thanks
