New owner, poor skimmer suction
lauzonaw
2
rochester ny
Hi everyone! I'm a new home owner, and new pool owner. As some background info, the pool is an inground kidney shape that I'm estimating somewhere in the range of 30-40k gal. My wife recently met our neighbors who mentioned that the previous owners had rarely been at the house for the past 5 years... so it's unknown if they really used or maintained the pool during that period. The cover on the pool was however fairly new. The pool has 2 skimmers, and 2 main drains. One skimmer (farthest from the pump) seems to have a plug in the second port, while the closer skimmer does not. There are 2 suction lines running to the pump... neither of which is labeled. Closing one off "appears" to close off the skimmers but I'm not 100% positive if it's closing one or both as the flow is so poor. I thought it was one line for the skimmers and one for the main drains until I saw the open 2nd port in the closer skimmer and now I'm questioning things.
So as part of cleaning up the pool and opening it, I'm obviously trying to get the bottom vacuumed up and all the debris out. However I'm finding the suction at the strainer baskets to be severely lacking. even with a completely empty basket, the suction is insufficient to suck any floating debris down into the strainer basket. in fact, I'd characterize the condition as a "slow flow" rather than a vacuum. The pump doesn't pulse... and doesn't "seem" to be running loudly or poorly... but I don't have a great comparison either. Sounds similar to the neighbors. Pool filter pressure is about 22 psi and is a large 4x cartridge type (approximately 8" diameter x 36" tall). I've tried emptying the baskets, hosing off the filter cartridges, switching the flow between the assumed "main" and "skimmer" repeatedly (at the suggestion of a youtube video... I didn't do this for very long as some banging noises were making me worry about water hammer). I also recently stuffed a hose down the far skimmer line with a pressure bladder attached... it made it about 20 feet before hitting a spot it couldnt pass at which point I turned on the hose and ran it for 30 minutes (pump off, assumed "skimmer" line open). I couldn't see hear or feel water flow at the pump or other skimmer. And this (the far skimmer) is the one I'd have considered to have the better suction of the 2. I know I'm getting decent total flow through the pump based on the water falls which are being fed a decent amount of water in addition to the 3 pool returns... but I'm working under the assumption that the flow is either predominantly from the main drains or just that the total degraded flow between the 2 skimmers and 2 drains is borderline sufficient for pump operation.
Given the novella above... what else can I try to unclog or test these lines... and relatedly is there any "good" way to tell how my pool is actually plumbed without digging it all up?
We recommend you run 90% skimmer, 10% main drain. If there is a valve on the suction side, close down the main side about 1/2-3/4 to draw more from the skimmers. You should see improved flow from the skimmers.
Skimmers also need weir doors to operate correctly, are weirs installed?
The water level in the skimmer opening needs to be 1/2 way up. Post pictures of the water level in the skimmers too.
Reactions: Jimrahbe
Will post pictures tonight when I'm home. In the meantime, there are weirs installed which appear to be working correctly based on my understanding (they move freely, floating with water level, water flowing over the top of them into the strainer). Water level is approximately 1/2 on one and between 1/3 and 1/2 on the other... either the pool isn't quite level any more or they weren't quite installed at the same height.
Good to know about the flow ratio... I'd been running both full open. Even with the main drains closed completely, the skimmer suction isn't sufficient to pull floating debris in the skimmer into the basket (IE: leaf in the skimmer stays on surface), and doesn't generate enough suction to use a pool vacuum (I feel zero flow with a vacuum hose attached).
Thankfully the previous owner left a little robot pool vacuum that I've gotten working and he's doing most of the work atm.
