- May 3, 2014
- 62,771
- Fiberglass
- Pentair Intellichlor IC-40
The salt will have no effect on your water chemistry. Best to wait until your SLAM is complete and then work on the SWCG.
Cool.The salt will have no effect on your water chemistry. Best to wait until your SLAM is complete and then work on the SWCG.
Walmart def has the best price around here. Attached is Home Depot, Walmart and Lowe's in the order.Yes wait until the SLAM is completed before you fire up the SWG. But you can add the salt any time really. Hold off turning on the SWG or turn it off if its on, until the salt is dissolved. Most SWGs don't like have high salinity water going through the cell when the anodes are active. Also I recommend adding the salt in stages of half, if your pool calcs say you need 500#, start by adding 250#, dissolve, test, recalculate, repeat. Nothing worse than over shooting your salt, and then you are draining to get the salinity down. I find Walmart has the cheapest in my area; Diamond or Morton. Stay away from the Clorox brand.. there is an interesting thread on the site about the Clorox salt.. it stained my pool.
What brand SWG is there? Its not in your sig. I would pull the cell and inspect it visually for scale and detritus. given all the gunk in your pool there may be some stuff stuck in there. If you see a lot of scale soak it in a 4 to 1 solution of MA until the bubbling stops. Don't over acid wash the cells if you don't have to, just if there are deposits. I think many people acid wash their cells too much.
Looking good! keep those pics coming its the highlight of my day to see the progress.
I can't figure out how to edit a signature on Mobile, am I missing something?What brand SWG is there? Its not in your sig.
I'm actually fortunate enough to have four tiny helpers who love to swim and don't care that the pool is a little green. Wife, on the other hand, appreciates the hard work but won't get in until it's clear.Also,.. in many of your pics I see you have a helper... its kinda cool to be in the pool and feel the salt dissolving.. its an endo thermic reaction and the dissolving salt is cooler than the surrounding water. Your "helper" seems will suited to experience this![]()
Ugg the dreaded concrete wash...We do ours a couple of times a year, and I cringe every time. This year we bought a surface cleaner, and wow it was painless. I highly recommend using one, it makes it so much easier, and the mess in the pool was significantly less using it.Just a side note. Since the pool still has days to go and the concrete can use a pressure washer, I would do it now so whatever makes it into the pool won't mess up a just finished water. At least 2 feet from the edge where you know for sure that's getting in the water as much as you think it won't, it will.
The SWCG is an Autopilot SC-48 controlled by a Pool Pilot Digital.
I'm not sure if the yellow bag has the Iron Control additive because Diamond Crystals makes a green bag product specifically made to fight iron. The yellow bag doesn't say anything about iron. In any case I already added a few bags of the yellow to test the SWCG. If the yellow bagged salt does in fact have some trace additives to deal with iron, how big of a deal is it?Do not use the salt in the yellow bags. It has an additive to control iron per the SDS sheet. The one in the blue bag someone above linked is the one you want as it doesn’t have any additives.
Or you could use the Diamond Crystal Pool Salt (they call it Splash Ready). Around here there’s very little price difference, with the pool salt version being slightly cheaper.
I am pretty sure that the yellow bags are okay since I have used Morton "iron" salt for a few months when a Kmart was closing and they were blowing them out. Green bag for Morton as well. I don't recall the Diamond Crystal yellow bags having anything but salt in them but they are the briquette type which with my particular softener is recommended. I would look but I don't think I have one right now.I'm not sure if the yellow bag has the Iron Control additive because Diamond Crystals makes a green bag product specifically made to fight iron. The yellow bag doesn't say anything about iron. In any case I already added a few bags of the yellow to test the SWCG. If the yellow bagged salt does in fact have some trace additives to deal with iron, how big of a deal is it?
Appears in your area the yellow bag is plain, no additives. Use it.yellow bag has the Iron Control additive
I know it was a weird price, I think it might have been a one time pallet price.$51 for the iron salt? Ugh I paid 4 bucks a bag when they blew them out. Probably why I haven't seen them at Walmart...
