5pm testing
CYA - 40
FC - 15
pH - 7.4
My CYA keeps bouncing between 40-50 but I know it's not changing much. It is gradually trending down as I'm not using pucks and I haven't added any stabilizer since last week and yet I'm backwashing and vaccuming to waste and replacing with the water from the hose. I think I keep getting differential CYA results because of the change in lighting throughout the day. I'm already on the 3rd bottle of CYA regent and I'm also going to need to order a replacement for the FC titrating agent. I got new leaf bags and a tail scrubber doodad for the Polaris and left that running again. I checked it after about 30 minutes and it hadn't picked up more then a cup or two of leaves. The booster pump seems to be nearly atomizing any air in the main pump system and injecting it back into the pool via the booster pump line to the Polaris as within minutes of hooking it back up there was a sheen of fine bubbles across the whole pool.
CYA - 40
FC - 15
pH - 7.4
