Unfortunately, I found this website after signing the contract, but I did get 8 quotes, so hopefully I covered most of the bases. Let me know what you think.
Only a few changes from the details/design provided below: we are placing 2 ft wide artificial turf around the sides rather than decking, and the spa tile will be Oceanside Muse Tourmaline Iridescent (7/8” x 7/8” offset) with the rest of the waterline tile being NPT 6”x6” simulated quartz grey. The glass tile we were originally quoted has mesh backing so we changed it to a paper mounted product. We are also looking at an additional deck drain to help with any storm water, etc. I attached a photo of a landscape design as well.
Pool:
Size – 16’ x 32’
Shape – Rectangular
Depth – 3’-6” to 6’-0”
Spa:
Size – 7’ round (360 negative edge, elevated 8”)
Specs – Six jets with tile facing, 1.5hp air blower, 400 000 Btu Jandy® heater w/ gas hookup and Wireless I-Aqualink
Steel Reinforcing - #3 rebar 10” on center, 12” bond beam w/ 8” walls
Shell – Pneumatically applied minimum 4,500 PSI (Lifetime warranty)
Skimmers – One large-mouth (turbo-assisted) skimmer w/ leaf basket
Main Drains – Two VGB compliant main drains w/ anti-entrapment covers
Returns – Three dedicated returns, plumbed in an equalized loop
Vacuum Line – One dedicated suction line for cleaner
Equipment – All Jandy® Pro-Series licensed materials are warranted for three yrs
Pump – Jandy® Stealth 2hp up-rated pump JEP 2.0SVRS
Filter – Jandy® C340 sqft. Cartridge filter w/ dedicated drain line
Lights – One Jandy® Full color LED light in pool and one in spa
Freeze protect – 24 hour timeclock with freeze protect sensor
Cleaner – Jandy® MX-8 Elite upgraded cleaner
Coping – Ivory bullnose travertine coping
Deck – ~600 sq ft of ivory travertine decking with deck drain ($16.55 per sq ft)
Interior Finish – Stonescapes Tahoe Blue Regular Pebble
Salt sanitizing system: Aquapure plc 1400
Total package: 80k, not including landscaping, additional drainage, fence, and artificial turf
Pool:
Size – 16’ x 32’
Shape – Rectangular
Spa:
