New liner is being installed
mwemaxxowner
354
Pageland SC
IMG_20221014_165933403_HDR.jpgIMG_20221014_165943744_HDR.jpgIMG_20221015_103356305_HDR.jpgIMG_20221015_103330340_HDR.jpg
I found someone I like to replace our liner. Our pool is 20x40 and the price is $4900. I don't think that was too bad.
It was interesting to see the pool under the liner. The bottom is concrete, the walls are fiberglass. He said he's never seen a pool like it.
I have photos that won't upload, saying they're too large for the server. I'll keep trying to figure out how to get those posted. None of the photos of the new liner will post. 🤦
Reactions: Lanzz
They were big back in the day. Search for 'hybrid pool' and you'll see alot of others. When they start to fail, they easiest permanent fix is to drop a liner in and have a vinyl pool because they fail from leaking at the seams, while the structural integrity remains great
I've seen that mentioned before.
The story I've been told (pool was put in mid 70's) was it began as a normal soft bottom liner pool. They had problems with ground water floating the liner, so they say they tried to combat that by putting concrete on the bottom and having someone "blow fiberglass in with a gun (?)" On the walls.
Then he says for some reason later they "went back with a liner".
It confuses me when he says "went back with a liner". When I look at what's there under the liner, I can't fathom using it with no liner. If for nothing else because it's terribly ugly, and the family it belonged to was all about appearances. But, apparently somehow they were using it that way with no liner nonetheless.
My wife's uncle was telling me this, and it's possible he has some parts of the story wrong. He was very young when all this was happening.
Anyway I think this has left me with a very nice IGP with a lot of structural integrity. Not sure what it was that worked but there haven't been any ground water issues floating the liner since I can remember.
When I was in middle school I met my now wife and started coming over and playing in this pool back then.
I know at least for a good 25 years there haven't been problems with that, thank goodness!
Looks great 👍🏻
It’s crazy how bleached out the old liner was when you compare it to the new one.
How old was it?
My vinyl pool was built around the same time. It has a vermiculite bottom and some sort of polymer sides. My liner was about in the same shape when we got the house. I actually thought they had used a white liner, because the blue pigment was completely gone. Your pool Looks good!
Reactions: mwemaxxowner
I guess I don't really need to worry about the pool being empty in the event it ever gets drained for one reason or another?
You need to worry *less* as it appears rather sturdy. 😁 Whenever you have a say in it, you'll want a minimum of a foot to 18 inches of water in the shallow end to keep the liner in place.
