Hello!
I have an issue with my new Intex pool installation, I am seeing some crud floating in the water that eventually settles on the bottom when not in use. It does not stick to any of the pool surfaces, but is also so fine that it tends to slip right through my vacuum's silt sock. I've been running the pump 24/7 to try and circulate it through the sand filter as much as possible but I'm not noticing much difference. Attached is a picture of the buildup on an extra thick filter I made for my vacuum.
Since filling the pool I have been bringing my water samples to the local pool store while following their guidance on chemicals. I've been relying on their printouts of my chemistry (weekly) and a cheap 4-in-1 test kit (daily). I just got my Taylor K-2006C kit today and collected these numbers:
pH: 7.5
FC: 0
CC: 0
TA: 180
CH: 210
CYA: 0? (test solution never went cloudy)
With regard to chlorine - I've been adding 1/2lb Re-Fresh 68% Calcium Hypochlorite in the evening and have very little loss by the next morning but by the afternoon my chlorine levels are back to 0. I tested again this evening 1hr after adding the shock and got FC: 5.4 and CC 0.2. Will test again in the morning with the new Taylor kit to verify overnight changes.
I'm guessing my CYA of 0 is because I haven't been instructed to add any stabilizer?
These are all of the additions and total quantities that have been added at the guidance of the local pool store over a period of about 5 weeks.
GLB Supersonic shock (first couple of weeks only)
DuraChlor pH down (sodium bisulfate, first couple of weeks only)
ProTeam Supreme PLUS (20lb, added at 3rd week)
Bio-Dex Protect-All Supreme (1qt, added at 4th week)
Natural Chemisty Pool First Aid (16oz, added at 4th week)
Currently using Re-Fresh 68% Calcium Hypochlorite and muriatic acid for shock and pH maintenance.
Also maybe relevant: Immediately after filling the pool we had unusually large amounts of consistent rain for about 4 weeks.
Thank you for taking the time to look at my issue, let me know if I can provide any more pictures or information.
pH: 7.5
FC: 0
CC: 0
TA: 180
CH: 210
