Hello,
I recently changed it out an easy touch circuitboard that went bad for an Intelitouch i10 3D. There are some differences I’m trying to wrap my head around. Here are my questions if anyone could help me troubleshoot.
1. I have my VS pump set to run at a medium RPM most of the time for filtering and chlorination, but I run it at a high RPM for an hour or two in the morning for the skimmer. My SWG is powered through a relay connected to the “pool pump” socket on the circuit board. It appears I could only choose one RPM setting to trigger the pool pump relay. Is there a way to run the saltwater generator whenever the pump is running?
2. I have a heater bypass valve. The new circuit board only has room for two valves without the expansion module. Is there a workaround to control a third valve using any of the other connections? Aux etc…
3. Valve assignments. Only two sockets without an expansion board. I have my intake and return valves and the A and B socket for now. I’m surprised I can’t just assign them as intake and return. I have them set to change whenever the spa heater is active for now, but that does not allow me to have a spillway for spa water circulation with the pool. Assuming I need an expansion board for my heater bypass valve anyways, what’s the best way to get the spillway to work? I do have a manual valve on the pool return to divert a little bit to the spa when the pool is filtering. I’d like to be able to turn on the cascade from the spa to the pool (pool suction, Spa return) for the waterfall look.
Inground Freeform plaster pool and spa
Pentair inteliflo VSF
Pentair whisper flo water feature pump
Intelichlor SWG ic 40
Master temp 400k with bypass valve
DE filter
Intelitouch i10 3D controller
Intelibrite led lights
Programming and control with Screen Logic
DE filter
