Hello, I got myself in the deep end, literally. We just purchased a new home with a pool. I've never owned one before and found TFP before we finalized the sale. The previous owners opened the pool for the year, but it looks like they didn't maintain it since then. I've been trying to get it back into proper balance for use, but turning out to be difficult. It is an IG vinyl lined pool, ~35545 gal (18' x 44' rectangle), 1 hp Whisperflo Single Speed Pump, 48 sq ft Pentair FNS Plus DE Filter with a CoverStar autocover. The water was clear and when I first tested with my Taylor K-2006c (I didn't run a full test) on 6/22, my results were:
FC: 0.0
pH: 7.4
TA: 240
CYA: 100
Temp: 80F
I added 2 lbs of hth Super Shock as that's what I had from the previous owners on 6/24. On 6/25:
FC: 1.0
CC: 0.0
pH: 7.4
TA: 220
CH: 500
CYA: 45
CSI: 0.42
Temp: 78F
I've vacuumed almost every day with my Dolphin Oasis z5i. I brushed the walls on 6/26 as there was algae on the walls, I added 5 lbs of Utikem One Shot Shock (50% Cal-Hypo) that evening and the pool started appearing a little green, especially the morning of 6/27 and much cloudier. I tested the morning of 6/27:
FC: 1.8
CC: 0.0
pH: 7.2
CSI: 0.21
Thinking I simply needed to get the the appropriate FC level, I added 242 oz of 8.25% Bleach as per the PoolMath app. I vacuumed and backwashed the filter thinking that it needed done as the pressure was 24, after backwash, I'm still at 24. Recheck of the FC later that evening was 1.0. Thinking I needed to SLAM, I added the bleach I had on hand, 726 oz of 8.25%. When I checked 3 hours later before bed:
FC: 9.2
CC: 0.4
I put the cover on it to try to limit FC loss overnight, especially since it wasn't terribly high. I ran a full test this AM:
FC: 5.6
CC: 0.6
pH: 7.4
TA: 180
CH: 460
CYA: 90
Temp: 82F
CSI: 0.28
The color is much better, but it's still cloudy and I'm having a lot of FC losses, even with the cover on. I guess the question is: Am I precipitating out calcium with the high CH and that's what's causing the cloudiness and FC loss or am I still working algae or some combination of the two? Do I just need to do an appropriate SLAM and it should even out? We're buying a lot more bleach today to try to get there.
I do have a new filter grid that I am going to install with my new PureLine Prime Variable 2.7 max HP pump as soon as it arrives from InyoPools to try to improve my energy efficiency.
Thanks for the help! My PoolMath logs are in my sig, but the times are not crossing over appropriately from my Samsung S8+.
FC: 0.0
pH: 7.4
TA: 240
CYA: 100
Temp: 80F
FC: 1.0
CC: 0.0
pH: 7.4
TA: 220
CH: 500
CYA: 45
CSI: 0.42
Temp: 78F
FC: 1.8
CC: 0.0
pH: 7.2
CSI: 0.21
FC: 9.2
CC: 0.4
FC: 5.6
CC: 0.6
pH: 7.4
TA: 180
CH: 460
CYA: 90
Temp: 82F
CSI: 0.28
