One follow-up to this, because I found it interesting. I called the dealer and spoke to one of the installation managers. He was very familiar with both the hot tub and water chemistry. I had some questions about the freshwater salt system. In the middle of the conversation, he said to me that he was not trying to convince me to use the frog @ ease system at all, and that there are some benefits to going saltwater , but he did not want me wasting money on false premises.
Hey, said that if my particular frog system was keeping chlorine too high, he thinks something is faulty with the cartridge, and he will gladly replace it. He said the issue is typically low chlorine instead of chlorine being too high with those types of systems, and they need to be nearly fully opened up to maintain chlorine levels properly. He pulled up the information off of their website and the frog system does not, in fact, have any CYA in it. He said that is a main benefit to why they use that type of system instead of granulated chlorine. He said with a system like that. I may need to add liquid bleach every so often, but that I could easily leave that in the hot tub while going out of town for a week and a half and not have to worry about my chlorine dropping too low. He said once they are dialed in, and you know the settings for your hot tub, it is almost maintenance free. I had zero intention of trying that system again, but after talking to him, I’m thinking it might not be a horrible idea.
I’m doing OK with the Dichlor and bleach method used here, but, it seems to be all over the place. I have tried a couple of different bottles of bleach and a bottle of chlorinating liquid at 10%, and using the pool math effects of adding tool, none of them seem to be the strength that they stated on the bottle. It seems to be all over the place. I know that bleach weakens over time, and there’s no way to stop that, but I am consistently chasing chlorine on a daily basis. I add to where I think it should be 7ppm and when I check it the following morning it is 2.5 ppm. Other days, I think it should be 6 ppm, and it reads 10 ppm. I know it’s never going to be absolutely on the dot, but I would expect to be a little closer than that with consistent usage.
