Hi all, my wife and I recently purchased a house with a 22k gallon pool. I know nothing about pools, but thankfully found TFP and read through pool school (multiples times haha).
I went ahead and purchased the TF-Pro test kit. It arrived today so I was able to do some testing. After testing I took a sample into Leslies. I know they aren't the most accurate but I wanted to see if my numbers were somewhat in the same ballpark just to make sure I didn't majorly screw up any of the tests.
Here are the results from my test with the TF-Pro
FC - 0
PH - Over 8.2 (it was a darker red than the max 8.2 reading. Leslies had it at 8.5)
Total Alkalinity - 270
CYA - 50 (Leslies had it at 31)
Calcium Hardness (180)
So after looking at the results, seems like I have a lot to do. The lady at leslies told me I need to add 6 gallons and 31.45% Muriatic Acid over the next couple days. Based off what I have read here I thought that was WAY too much. Pool Math is telling me I should add 104oz.
Assuming pool math is correct, how does my plan look?
1) Add about 104oz of 31.45% Muriatic Acid (in doses of 1 Quart)
2) Add about 169oz 10% liquid chlorine
3) Add about 55 lbs of Calcium Chloride
Thanks in advance! New to all this but doing my best to learn as quickly as I can
FC - 0
