We are looking at an inground pool install in Panama City. We have gotten quotes from the two builders with the best reviews that we've found so far. We are at the extremely early stages of this process and are looking at a 15'x35' pool that goes from 3 ft deep to 6 ft deep. Here is a sketch of the pool and deck:
Pool - Album on Imgur
I'd like some comments from the group on the quotes. My first impression is :
the base prices include different items - for instance the deck sf are different between the two and in fact the one is missing a few hundred sf of deck space (it will be close to 1000 sf). There are a few other items that are different too.
Neither quote is specific to model numbers or equipment sizes- I will get them to specify this in the next iteration
The second quote has the incorrect depth of 5ft instead of 6ft while the first does not include the steps from the house.
Any other comments on materials or anything?
We're probably going to get some quotes on stamped concrete decking directly from a sub.
We will go with the variable speed pump and SWC.
Does anyone know how SWC retail consumer prices compare to pool builder marked up prices? I'm pretty handy and if it were several hundred dollars cheaper, I would think about changing the standard chlorinator out myself. Are there other components that would need changing too?
Is one skimmer sufficient for a pool like this?
We plan on buying a robotic cleaner ourselves.
I don't know what to think about the "free" rotating heads. Sounds like a future maintenance problem. Anyone have experience with this system?
I welcome any comments.
Quote 1:
15’x35’ in-ground pool 3ft to 6ft deep
Base Price = $29,500
· Permits
· Excavation
· 6”shotcrete pool shell with #3 steel 12” oc
· One row 6”x6” Frostproof tile
· One row 4”x8” Bullnose Brick Coping
· Two main drains, one skimmer, two pool returns and one pool cleaner outlet
· One 1hp pump and one high rate sand filter
· One Rainbow 320 Chlorinator
· All sch 40 PVC pool plumbing
· One set steps and one ladder or swimout
· Marcite interior of pool (blue quartz)
· Vacuum and cleaning equipment
· Start up chemicals
· One 12v LED white light
Options:
Salt generator system $1,795
Upgrade to var. speed pump $700
Two color LED lights Included
926 sq ft stamped concrete $11,115
Water line for future water feat Included
Quote 2:
15’ x 35’ Rectangle Pool - 3’ to 5’ Pool
Shotcrete - An engineered steel reinforced shotcrete shell. (Our crews are ASTM certified with
over 75 years in the art of shotcreting.) Lifetime Warranty
Cleaner- Pre-plumbed for future robotic pool cleaner. (pressure or suction)
Standard Skimmer
Tile - 6X6 frost proof waterline tile (stock), set with pre-mix tile base and grout. Aquron is applied to beam and grout to water proof area to alleviate bleeding of calcium
Deck- 3ft Surrounding Pool (371 Sqft Included)
Plaster –Blue Quartz Plaster 5 Year Factory Warranty
Lighting- (2)- 12v 1.5" L.E.D. underwater pool lights
Filtration System- ¾ HP Single Speed, 27” Sand Filter, and equipment pad.
Maintenance Equipment- Manual vacuum equipment, brush, and test kit.
Base Pool Price
29,750
Additional / Optional Equipment
Ecopool – Total water circulation with three Rotating in-floor heads - Free Promotion
- with Venturi Skimmer
1.85hp Variable Speed Pump $1,000
Upgrade to Cool Blue Pebble Plaster 15 Yr Warranty $2,160
40K Salt Chlorinator $1,600
4ft Bench in Deep End $400
5ft Shallow End Bench $250
365 Sqft of Extra Kretekoted Deck $3,650
Concrete Staircase and Landing $3,400
41 Ft of Deck Drain $287
Additional / Optional Equipment Total $12,747
Total Base Pool Price plus Additional / Optional Equipment $42,497
Services not Included Above
Landscaping
Alarms for Doors and Windows Required by Code
Electrical Estimated at $1,800
Quote 1:
· Permits
· Excavation
Options:
Quote 2:
Standard Skimmer
Base Pool Price
29,750
Landscaping
