As for volume u only count the water height not the wall height so I figured that on 48” of water.
As you dose & test the results you’ll be able to fine tune your volume calculation.
You have no cya so you’re chlorine won’t last long & your swg will have a hard time keeping up since it will be consumed by the sun quickly. You need around 70 ppm cya when all is said & done but for now get about 40ppm dissolving in a sock infront of a return & use liquid chlorine to get to 5-7ppm fc daily so nothing grows while u wait on your swg to take over.
FC/CYA Levels After cya has been dissolved for 24hrs or so retest & then add the remainder so u don’t overshoot.
It takes many hours for your swg to produce that much fc. Boost just makes it run for 24hrs. It only makes a finite amount per hour . Swg’s are meant to maintain fc levels , not get u there from zero or overcome algae so when u need a boost dosing with liquid chlorine is best.
Then you can see if your swg can maintain it & adjust it accordingly.
Your ta is low so add baking soda to get to 60ppm (shou
- your ph is fine. No need for borax.
Even if your volume is 9700 gallons & u added 8 - 40# bags that would put your salt level @ almost 4000 ppm. Most intex units don’t really like more than 3000ppm & will usually throw a high salt alarm.
It’s usually advised to add about 3/4 of the salt poolmath calls for , let it circulate 24hrs, then test & add whatever is needed to get to your target so you don’t overshoot it because just like with cya the only way to lower it is a water exchange.
With all your dosage #’s being so large i wonder if your pool volume is correct in the setup of
PoolMath
