New Fiberglass Owner; Looking for tips on keeping pool pristine.
JoePug76
3
Mint Hill, NC
Just had a 14x33 Fiberglass pool installed. All Jandy equipment: VS Pump, Heater/Chiller, Salt Chlorinator, LED lights. Automation for Pump, Heat/Chill, and lights.
I would like to learn the ropes on how to best run my equipment to maintain the pool running year round efficiently. Any advice is greatly appreciated.
  • Love
Reactions: Mdragger88
Thanks guys.
What are the recommended VS Pump speeds? Now that it is getting colder?
Pool builder pre-programmed me at:
Priming speed 3000 (RPM) for 2 minutes then it drops to 2200 (RPM) constantly.
When my heater/chiller kicks on it goes up to 2750 (RPM)
Freeze protect is set to 2650 (RPM)
You likely can dramatically lower the rpm of your pump.
I suspect your SWCG is off due to cold water, so are you adding liquid chlorine to the pool as needed. If so, you can lower the base rpm to a level that is sufficient to skim the surface of debris. If you have a 3 hp VS pump, your base rpm can likely be about 1400 rpm or so.
Have you tested that your heater needs that high of a rpm? Likely can get away with 2000 rpm or even a bit lower.
Freeze protect just needs to move water, so it can be the same as the base rpm.
The pool just got started up. I have the heater on right now and my water temp was 95 yesterday. It is getting colder this weekend so I am
going to shut the heater off and save on utility costs since we probably aren’t going to have many more days in the high 60’s any more.
