- Jun 2, 2021
- 27
- Pentair Intellichlor IC-40
Hello all.
I'm about to start renovating my 20 year old pool. I'm also replacing most of the equipment and wondered if it's time to rethink the current filter.
I have a Jandy Del60 DE filter currently. Over the last 2 years since we moved in, the filter and I finally reached an understanding, especially after moving from DE to cellulose. Once I figured that you can't add much beyond chlorine and ph adjustment (anything else just prematurely clogs the filter media) and realizing for clear water, that's kind of all you need anyway, it's been great.
However, despite recent rains, here in CA we do struggle with water levels which has prompted me to avoid backwashing and instead jump through a number of hoops to change the DE (Cellulose fibre) without losing too much water. I would pump water from the filter drain into a barrel and save it for reintroducing later, or for the plants once the chlorine burned off. Then I'd have the actual messy job of hosing down the grids, while also trying not to waste too much. Overall I think I've been quite successful, but it's not easy or quick.
I have read that cartridge filters are easy to use and save water. However, the filtration not being as fine worries me as the algae levels in this pool are a real battle. This might be in part thanks to a lot of vegetation in the yard that I can't avoid, plus the CA sunshine. I've also read that there are limits on the flow rates you can push through them. My soon to be replaced 1 speed motor is 2.0hp . It's replacement will be VS, but I don't know how hot I'll have to run it for the spillway to function.
Wondered if anyone had any thoughts on this, or any experience with the newer Pentair et al filters with quad cartridges that are still DE based, but have greater ease of operation.
Appreciate any thoughts.
Thanks
Thanks
