I got a thread in under construction but figured you guys here know better. I got pool filled and plumbing done last weekend and started slamming pool I had residual green water that I thermally exchanged w fill water to thin out starting saturday afternoon. yesterday pool was sparkling clear im gonna do an OCLT 2nite im positive im good tho. I tested my water (have tftkit) and i had 400ppm salt on fill water. I have 13k gallons so I got nine 40lb bags of morton pool salt (only thing avail here except pricey pool store salt). I know to add about 7 and test and go slow to not overshoot, and Im letting FC drop naturally if I pass OCLT 2moro. So far Ive been running pump 24/7 at 75% to clear water, today I backed it down to 50% because I cleaned out filters last night lots of dirt in them. I can figure out the automation setup and the T15 startup and all that.
Ive been reading and theres alot of differences of opinion. How long should I run the pump for and what percentage? Ive read 1200rpm is needed to make switch close contacts. I know to leave salt in for 24hrs then test and go from there but what setting on SWG I read 50% is a start. And the pool gets full sun in morn till early afternoon then all shade from house, when is best time to run pump? daytime to make FC while sun is on it or at night? When should I bump up my CYA to 70 Im at 35ish now. anybody with similar setup plz tell me what you do with yours.
thanks in advance
thanks in advance
