Hey everyone! I've been lurking a long time, but finally got a pool. It's a Coleman Power Steel Oval pool 26'x12'x52". The box says it's 7,966 gallons, but when I put the numbers in the pool math calculator I came up with 9000? It's possible I put the numbers in wrong.
Anyway, if I read correctly, if I buy a SWG, I won't have to add bleach daily? Would a SWG work with the pump that came with this pool? I can't really find anything about it except it says the pump flow rate is 2000 gallons and system flow rate is 1500 gallons and it's called SmartTouch. I was thinking of the Intex Krystal Clear Saltwater System if that would work with my filter pump.
I know I need a TF100 Test Kit, but would I need the Taylor K1766 salt test also?
Any other helpful hints about set up and anything else I might need to get started?
Thanks!
Nancy
Thanks!
Nancy
