Hello Every one. I finally got my permit and I'm getting quotes from Subs right now. I initially got quotes from 4 different pool contractors but figured I'll pump the saving from doing it myself into the pool build.
Here are the details:
I'm building a 15' x 30' simple pool 3' to 6' without spa, travertine deck with total of about 15000 sq ft of travertine
Here are my questions:
1. The engineer specified #4 rebar with 12" floor and 8" walls widening to 10" think wall and beam at the top. The subs I've given the plans to are telling me that it's over kill and it's going to cost me much more? Has anyone used similar rebar/gunite layout?
2. Pool is only 15,000 gallons but the engineer specified 340sq ft filter with 1.65 variable speed pump. Is that overkill as well?
3. I'm about to start the hole with the excavator. How much extra space do I need to leave all the way around for plumbing? I see recommendations here to drop gravel in the bottom to lay rebar on. How much gravel is recommended? Any gravel better than others?
4. I initially thought I was covered with my regular fence and didn't need a fence or net for the pool to meet code but after reading around I see that the horizontal cross member on the fence need to be over 45" from the ground if those members are on the side of the fence opposite the pool to neighbors kids from climbing into my yard and drowning I guess. Well mine are at 38" so I'm going to need a protection at the pool. Any recommendations lowest cost option?
4. I'm looking to install decent equipment and would like to control of pump, heater and lights via IOS app. here is the gear I'm looking at and would appreciate comments on any experience especially on the mix. I'd like to stay with the same brand for automation ease.
Pump Jandy Vsfhp165AUT (1.65 HP variable speed)
heater Jandy JE2500T (119k btu heat pump)
Filter Jandy CL340 (340sq ft cartridge filter)
Lights Qty 2 Jandy JLU4C30W100 (30 watt colored LED light nicheless)
Chlorinator Jandy APURE35 (35k gallon chlorinator)
Controller Jandy zq-4pi (Iaqualink Z4 controller)
Skimmer aquastar SKR103
Drain 32CDFLV102
Jandy automated valve for pool feature waterfall
Still need power supply for lights (assume any 12 V power supply that has sufficient amp rating will work)
circuit breaker panel (thinking about using standard Nema 3R 8 circuit load center)
Advise is really appreciated since this is a bit overwhelming and a lot of Money.
Drain 32CDFLV102
