We had our IG completed on Friday. It’s about 22-24k gallons based on my math, with a pebblesheen finish. The builders came and added chemicals. I know acid was part of it and a bunch of other stuff. I was left with 4 gallons of acid and 4 gallons of chlorine. I was told to add a gallon of acid today and if the ph was good it was ok to swim.
I used my basic test kit today since my DPD-FAS kit is on the way. Before adding and acid, my PH was about 7.2 and there was ZERO FC. Total alkalinity was 40 PPM based on the test results.
Why would I want to add more acid if my current results are in range? It seems as though I would want to raise it a touch if anything. My alkalinity needs to be raised as well. I don’t want to go against my builders suggestion, but something doesn’t seem to make sense.
