Re: New Build in Red Stick- **pic heavy**
So here are the pics:
So I was all anxious for them to show up. For some reason I thought they had a mixup scheduling my shoot so fast. I mean when I called the owners wife to schedule, it was like a 90 second phone call. She just said "how about tomorrow morning?" and I said "ok great!" and that was pretty much it, just couldnt believe ut I guess.
They showed up about 5 mintues early and were hustling from the get-go. They were shooting gunite about 15 minutes after they got there. That was the very first thing they did was put a guy in the pool with the hose and he started shooting a pad to stand on.
The trucks, two gunite (cement and aggregate in separate compartments with a feed mechanism) a huge compressor truck, and a pickup full of guys all arrived within seconds of each other and it was like a chinese fire drill they piled out so fast and everybody was carrying a full load on the first trip to the back yard. No wasted time.
Then the foreman came to talk to me, after looking over the whole pool. He asked to see the plans, glanced at them and focused on me describing what I thought were the critical points of the pool that may have been non-standard. He picked up right away on the spa wall being at water level, nodded and trotted off into the pool and talked to each worker giving them the layout.
Then they started correcting stuff in the pool, filled the drains with mud, covered the skimmers, started stringing up steel guide wires to guide the shoot.
Then Raul (the foreman) came and asked me if I had any more rebar (I did) and asked uf they could add it to the pool shell. SURE! But why? He wanted to strengthen parts of the shell that he thought might be weak. Specifically the overdug wall and some on the back wall that turned out to be pretty thick. I felt pretty bad at this point that I had done a poor job, and he laughed and said no, no, (major local pool builder) doesnt build them this good, we have to bring alot of rebar to all of his jobs and waste alot of time correting what they do wrong.
Whew.
I was also very glad that he cared enough to do that. He said several times that he wanted me to see that he wanted the best for my pool.
From all the really good suggestions he made I believed every word of it.
Shooting the tanning shelf initial lift so the guys could get into the pool and not deform the rebar too much
Starting to hit the bond beam
Working the spa
Later in the shoot finishing the spa
starting the steps.. the steps were done in several different stages with long minutes in between where they went to work on something else. I wonder if thats on purpose to let them set up
Raul asked at one point... "you like squares and rectangles, sharp corners eh?"
Yes.
I asked him to cut in holes for my umbrella holders, and he said he was pleased to, glad I had gotten some because he could tell my wife was very pale-skinned and he didnt want her to burn (yeah he said that, wtf?).
and he walked around with all four after I gave them to him and told him where I wanted them, then came back and said he would put them wherever I wanted, but could he make a suggestion? Sure, so he laid out where he would put them and why, with the afternoon sun (which he had never seen but guessed at) and sure enough he had the better layout so I told him to go ahead.
The gunite trucks were RIDICULOUSLY loud. The vibrators in the bins combined with the air driven material pump was overwhelming. When they switched trucks and it got quiet it was almost eerie.
getting close! On the last truck. We used 42 yards. The company owner estimated 30 yds (I had run some rough back-of-the-napkin calcs and said 35-40), so we were both too low. That overdig really cost. But I would rather pay to fill it with gunite than have a settling void to worry about.
finished spraying and running out the hose. They were kind enough to run out the hose into the void around my little drainage sump to help fill it up. That was good thinking.
smoothing out the bottom.
Finished, cleaned up and left. I gave Raul a largish extra amount for all his thoughtfullness and asked him to split it among the crew.
Final pics of the shoot.
